-   -   Gas Water Heater leaking (http://www.diychatroom.com/f7/gas-water-heater-leaking-126174/)
pressingon 12-10-2011 12:29 PM
I have a 50 gal AO Smith hot water heater that seems to be leaking. Problem is, I can't find a source. I look around the top inlet and outlet connections, no leak. I look around the release valve, no leak. I look inside below the firing chamber, no water. But under the base, there is a puddle and it keeps coming out very slowly. Any suggestions on where to look for leakage, and how?
Thanks in advance. Tim
Service plumber 12-10-2011 12:40 PM
Sounds like tank leaking
pressingon 12-10-2011 12:58 PM
Ok--tank leaking, but how do I check that? and where is the most likely place that it would leak?
tribe_fan 12-10-2011 04:00 PM
If you have eliminated the inlet, outlet, and pressure - you are looking at replacing it. How old is it?
They tend to fail completely on Christmas eve....Murpheys law.
oh'mike 12-10-2011 04:08 PM
The tank has a rust hole --no fixing that---sorry.
