#16 | |
Roofmaster
Gas water heater installationQuote:
Also, I assume you have a louver going in near the bottom for air intake?
" A lot of men build things, and a lot of things fall down " |
#17 | |
JOATMON
Vent? You mean like this? I made my own cabinet...14g aluminized steel.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#18 |
registered
Its a straightforward in stall for a plumber. Doesn't get any easier then your set up. I don't know where your at. I would think 7-800 installed. 1 hour job. Where i live i could sit it out on garbage day it wouldn't make it to the garbage man. There is black guy who comes around early a.m in pickup looking for stuff like this.
#19 |
Roofmaster
Even double wall should be a couple inches from wood IMO, but very nice work otherwise. Keeping spiders out of the intake could be challenging though, they are gonna love the heat down there, Like Club Med for Arachnids
#20 |
Master Plumber
Every time i see a water heater installed with those flexible lines connectors i go off the chain these are the biggest
rigs, sloppy unprofessional and eventually they will leak. Oh by the way 1000 bucks is a great price we we would charge about 1400 the install would need to be brought to code and permits pulled every time on gas this keeps me clear on liabilities if the heater should ever have a major problem that involved loss of life or damages.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 01-12-2013 at 08:55 AM. |
#21 |
That price is also including the cost of a proper permit being pulled.
#22 | |
Special User
I would always replace flex lines when replacing a WH though. But, I guess hard piping makes homeowners more likely to call a plumber, so I suppose it's a money-maker for the pros.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk. |
#23 | ||
JOATMON
One of items on my 'list' is to put a cover over the hole where the pipe transitions into the troft going up to the roof. Quote:
#24 | |
Experienced HVAC Tech
#25 |
Master Plumber
[QUOTE=tylernt;1091682]I dunno, compared to the royal pain of hard piping, it's worth the small risk. Besides, if water conditions are gonna pinhole flex lines, hard pipes will eventually pinhole too.
pin holes on M/K/L ? have you seen the gauge on those copper flex hoses, In my opinion its called lazy, and as for earth quakes foundations settling, men from mars rocking the water heater, has anybody ever heard of expansion couplings.??? aka flex couplings aka anti vibration coupling. among other names . i remember the days if a plumbing inspector found you failed to wipe down a solder joints he,d fail you on the spot, it was called workmanship. dead and gone thats why the trade has gone to s ![]() Copper flex couplings used by DIY acceptable by supposed professional plumbers i don't think so. but that's my humble opinion
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 01-12-2013 at 05:00 PM. |
#26 |
Gas water heater installation |
#27 |
registered
NO permit needed where i live. I guess some municipalities want to reach into your wallet every chance they can. I had my water heater replace two years ago. I think 7-8 was the bill.
| Display Modes | |
| Installation and support of water heater expansion tanks. | Homerepairguy | Plumbing | 46 | 01-28-2013 06:55 AM |
| Turning off hot water to fix 1/2 inch CPVC pipe in crawl space | steve3847 | Plumbing | 21 | 12-20-2012 02:53 AM |
| Hot water heater installation | Nospammer | Appliances | 7 | 06-22-2011 08:12 PM |
| Poor Hot Water Pressure After HW Heater Flush | linuxrunner | Plumbing | 4 | 04-07-2011 08:24 PM |
