Gas Water Heater Dripping Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2011, 07:23 AM   #1
Gas water heater dripping water
I bought a new hotwater heater (nat gas) GE brand and everytime it fills up, water starts dripping down the inside of the tank onto the pilot light/burner, until the tank is warm. I know it may be caused from condensation but it does it every single time i use hot water until the tank has heated back up. Is this really normal everytime? it's becoming annoying and my old tank never did this. I can understand maybe once in awhile it doing this, not every single time we use hot water.
NOTE I checked the top of the hotwater heater vent cap/flu pipe and there is no water dripping down into hotwater heater from flu pipe, so the cause would be from inside the tank. Could it be from really cold ground water heating up? I dont know what else could cause this.
steve k is offline   Reply With Quote
Old 12-06-2011, 07:34 AM   #2
Rewards Points: 1,442
Can you tell whether the water is coming from inside the water heater versus dripping down the flue up above and then into the middle of the heater?
I would not expect condensation to form inside the heater.
Old 12-06-2011, 09:51 AM   #3
biggles's Avatar
if the flue is cold from the outside air it will condensate down into the burner from the flue as the burner heats up it might be the cold air and not the cold water causing it...
Old 12-06-2011, 09:41 PM   #4
I was hoping it would be condensation from the flu pipe but i checked and no water dripping from flu into hot water heater. could it be a bad tank? my last tank was the same brand and it leaked from the top so it was replaced with this one (Warranty covered it)
Old 12-06-2011, 09:45 PM   #5
I checked and no water is dripping from the flu pipe into the hotwater heater, its from the inside of the tank. my last tank was replaced because it was leaking from the top and flooded my laundry room. warranty replaced it with this one. Could it be a bad tank? or could it be from really cold ground water heating up? It's only a 30 gallon tank so it only does this when its almost completely empty of hot water, if i use a little water it doesnt do it at all.
Old 12-06-2011, 09:50 PM   #6
the very cold water coming into the bottom of the tank is causing the condensation. the burning gas realeases water vapor from what ive heard and that probably condenses on the colder part of the tank at the bottom. I remember the first gas water heater i installed did that and i thought it was a leaker also.
Old 12-06-2011, 09:55 PM   #7
Ok, thats good to know. thanks! after that last hot water heater i had i get kinda nervous of any drip or leak i hear.
Old 12-06-2011, 10:47 PM   #8
biggles's Avatar
if it was a water leak it wouldn't stop and go the tank is on the cold water side of the house feed water 50psi minimum coming in has to be cold condensate off the bottom of the tank....
Tags
hot water heater problems
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Smelly brown water from water heater timthetoolman Plumbing 2 05-19-2011 10:32 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
