Gas Water Heater Combustion Air - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2013, 08:30 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
Originally Posted by jagans View Post
Yeah, it can serve as the droop, it just can't serve as the drip
So what do ya do if you've got both a droop and a drip
MTN REMODEL LLC is offline   Reply With Quote
Old 06-03-2013, 08:54 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 814
Wipe your chin and move on
Old 06-03-2013, 09:21 PM   #18
EPlumber... Sounds like ya got some good experience... I'll pass it along.
Old 06-04-2013, 01:31 PM   #19
FClef's Avatar
Rewards Points: 160
Originally Posted by handy man88 View Post
Yes, I see that in my iron pipe. Does it ever need to be cleaned?
I have only ever had to clean out sediment traps once in my career. It was for a greenhouse complex that had propane. Their consumption was about 30,000 gallons a year and we put a vaporizer in the system. It turns out that the driver was not draining the scrubber every time he delivered and the system picked up a dose of "heavy ends" or the oily bits of sludge that can occur when you use heat to vaporize propane. I spent two weeks in winter at that complex every day just taking apart sediment traps and emptying the gunk out so our customer wouldn't lose his plants.
So the answer that it is very rare to have to clean them is pretty accurate.
FClef is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Sealed Combustion Furnace and Tank Hot Water Heater Yippee HVAC 6 06-16-2009 12:32 PM
