Gas Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2013, 07:31 AM   #16
bbo
Originally Posted by rosem637 View Post
How long do you think this would take? A week? A month? A year? Century? Millenium?
Probably longer?
possibly shorter.
I don't think anyone can answer that with any certainty until it fails, then you will know for sure.
bbo is offline   Reply With Quote
Old 02-18-2013, 07:42 AM   #17
Rewards Points: 1,492
Originally Posted by gregzoll View Post
Nothing would have happened with the gas coming out, even if he was smoking a cigarette, while removing the old valve and screwing back on the new one.
It would have to be enough concentration in the room for anything to have happened, while the cigarette was lit..
It might not have caused the entire house to explode but it could have behaved like an old fashioned gas light when the lamplighter comes 'round. Enough to startle him and he drops the valve and jumps aside and the "gas light" stays on. Big enough (much larger than a gas streetlight or a torch used for soldering/sweating) to set nearby things on fire.
Old 02-18-2013, 07:43 AM   #18
In 87% OF THE TIME IT WILL CAUSE NO PROBLEM. You do have to worry about galvanic corrosion 72% of the time, depending on force of contact and surface area of contact, with a damp basement add 19%.
paintdrying is offline   Reply With Quote
Old 02-18-2013, 08:35 AM   #19
Rewards Points: 214
Originally Posted by bbo View Post
possibly shorter.
My comment was being sarcastic. I laughed when I read the comment about that nut wearing down from the vibration of the dryer to the point of causing a leak.
rosem637 is offline   Reply With Quote
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
