Gas Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2013, 01:00 PM   #1
Dave Sal's Avatar
Rewards Points: 592
Gas valve
Hey guys,
I'm getting a new washing machine installed today and was moving the old one out of the way and cleaning up the floor underneath and behind when I noticed the gas shutoff valve for the gas dryer. This shutoff valve was purchased in 2005 when I bought the dryer and was installed by the guy who delivered the washer and dryer. It's obvious that the red handle is facing the wrong way but it is still accessible so no big deal. My question is regarding the fact that it is touching conduit pipe, which I never noticed before. I'm concerned about the dissimilar metals causing corrosion, plus the fact that gas and electric don't play well together. I was thinking of simply keeping the two apart with a piece of wood or something. What would you guys do to rectify this situation?
Dave Sal is offline   Reply With Quote
Old 02-17-2013, 01:41 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
The two shouldn't touch only because of looks- really not a concern otherwise. But I'd take a 2-hole strap and mount it on the pipe or conduit and spread them a bit
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (02-18-2013)
Old 02-17-2013, 01:46 PM   #3
Roofmaster
Rewards Points: 2,172
Cut the tab off an asphalt shingle and slide it between the pipes. You have electrolysis going on there, so yes it is definitely a concern. Why did the installer locate the valve like that? On Krak?
Old 02-17-2013, 02:18 PM   #4
Dave Sal's Avatar
Rewards Points: 592
Actually he might have been on something. I remember that he didn't think it was necessary to shut off the main gas valve before removing the old valve. He unscrewed the old one while the gas was still on and all I heard was gas rushing out while he screwed on the new one. No time to make it face the right direction when gas is streaming out. I'm surprised that he didn't light a cigarette at the same time. I'll get something to separate the two pipes. Thanks for the replies.
Old 02-17-2013, 02:40 PM   #5
Roofmaster
The other day I pulled up to a gas pump and the guy in front of me was filling up a new corvette with a lit cigarette in his mouth. I said "Are you trying to commit suicide"? He said I didnt know what I was talking about, and that he has fueled cars a thousand times while smoking. I said yeah, but its that 1001 that gets you every time.
The point is that there are some crazy SOB's in this world, but it really isn't good to let them get too close to you. They usually end up killing someone else with their lack of care, not themselves, as they are one and all self- serving A-Holes.
The vibration of your dryer which will transmit and create wear between gas and electric conduits will eventually cause a disaster. I am sure that the guy that installed your dryer will cause a tragedy down the road somewhere, as he is thoughtless.
Old 02-17-2013, 05:34 PM   #6
Rewards Points: 13,296
Just need one of these.
http://www.bing.com/images/search?q=...lectedIndex=13
There's also no drip leg which would be a code violation here.
http://www.eaglespecinspections.com/observations.html
Dave Sal (02-17-2013)
Old 02-17-2013, 06:02 PM   #7
Rewards Points: 6,652
Nothing would have happened with the gas coming out, even if he was smoking a cigarette, while removing the old valve and screwing back on the new one.
It would have to be enough concentration in the room for anything to have happened, while the cigarette was lit.
As for the picture, really hard to tell anything from it, due to all I can tell is that the valve handle is correct, and there is nothing touching the black iron pipe. Really need a better picture, standing back farther showing what you are stating that it is touching.
Old 02-17-2013, 06:08 PM   #8
Plumber
Rewards Points: 452
TBH- I can't count the number of valves/caps I removed and replaced the way the OP described.
As for the picture- I thought he was talking about the conduit on the right side but after looking again i assume he's addressing the one behind the flex nut.
Old 02-17-2013, 06:16 PM   #9
Dave Sal's Avatar
Rewards Points: 592
Here is a picture with an arrow showing the area in question. The silver looking vertical thing to the right is an unused piano hinge hanging off of a hook on the peg board. Sorry for the confusion.
Old 02-17-2013, 06:22 PM   #10
Just put either two 90's to bring away from that conduit, or if you are able to shorten the pipe somewhat, you could do it that way. Too many ways to do it to get away from the wall a bit. Or even if you can, just take that conduit and move it up some, and also adjust the black iron with the gas line, so it is not that close to the wall.
Old 02-17-2013, 10:34 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 990
Should not touch, however electrolysis is not an issue in this case.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-18-2013, 07:07 AM   #12
Rewards Points: 1,216
It seems like 95% of the people are STUPID
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-18-2013, 07:43 AM   #13
DIY staff
Rewards Points: 7,174
90%--please don't exaggerate---------
Old 02-18-2013, 07:52 AM   #14
bbo
90% of statistics are made up on the spot.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 02-18-2013, 08:15 AM   #15
Rewards Points: 214
How long do you think this would take? A week? A month? A year? Century? Millenium?
Probably longer?
rosem637 is offline   Reply With Quote
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 08:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
