Gas Supply Pipe Size For Gas Range - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2010, 12:59 PM   #1
gas supply pipe size for gas range
i currently have a 1/2" gas line going to the gas range in the kitchen (3/4" to about 6' from range, then coupled to a 1/2" line the rest of the way). I talked to a plumber for some unrelated work, and he pointed out that the gas range really should be 3/4" all the way. Is that correct?
acerunner is offline   Reply With Quote
Old 10-07-2010, 02:49 PM   #2
Plumb or Die!
Should be OK.
plumber666 is offline   Reply With Quote
Old 10-07-2010, 04:23 PM   #3
Rewards Points: 1,216
1/2 " sounds OK.
COLDIRON is offline   Reply With Quote
Old 10-07-2010, 05:09 PM   #4
HVAC / Plumbing
The plumber knows the BTU'S of the range. I don't run anything smaller than 3/4 to a range & use a 5/8'' flex connector at the range.unless, the house is on a higher pressure gas system
kenmac is offline   Reply With Quote
Old 10-07-2010, 05:41 PM   #5
Don't know it all, yet!
My vote is for the 3/4.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-07-2010, 06:35 PM   #6
he never looked at the range. We were in the basement looking up at the pipes. What is the typical BTU rating of a range? So it seems the 1/2" is minimal code, but 3/4" is more appropriate in practice?
What's considered higher pressure? Do you need special gauges to measure it? I've heard typical is 0.5 ~1psi.
Old 10-07-2010, 06:41 PM   #7
HVAC / Plumbing
somewhere in the range of 65-70k total larger range more
Here you can get get 6'' wc or 2 # gas system. Lower pressures more volume with larger pipe. It will also depend on the length
Old 10-08-2010, 12:56 PM   #8
Rewards Points: 156
Turn your burners on one at a time. When you turn the 4th burner on, does the 1st burner have noticably lower output? No? 1/2" is plenty. Yes? go with the 3/4"...... assuming you regularly use all 4 burners on your range.
moondawg is offline   Reply With Quote
Supply Pipe sizing for bathroom/kitchen invertedflight Plumbing 4 02-04-2008 09:27 PM
Service size pipe 3/4 or 1 inch? kgphoto Plumbing 6 01-29-2008 06:23 PM
Steam Heat Pipe Size? helpless handyman HVAC 5 11-25-2007 08:10 PM
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 08:46 PM
blue or red pipe for radiator supply amakarevic Plumbing 2 07-23-2007 08:57 PM
