Gas Stove Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2007, 08:50 PM   #1
Gas stove installation
Hi guys, I am installing a new stove. I purchashed a new flexible gas line as well. Does any pipe compound go on the the gas line threads near the shut off valve? Also does any pipe compond go on the stove side connection? Or do I just thread on and check for leaks? Also is a spray bottle with soap good enough to test for leaks? Thanks
helpless handyman is offline   Reply With Quote
Old 11-28-2007, 08:53 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Thread on and check for leaks if it's a ground joint type. Soap is fine.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-29-2007, 05:56 PM   #3
Send a message via AIM to Marlin
My rule is if it has threads it gets dope.
Marlin is offline   Reply With Quote
wood stove insert Karpol General DIY Discussions 5 11-25-2007 11:56 AM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
