Gas Stove Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2010, 02:43 PM   #1
Wink
Gas Stove Install
I have 2 appliances on gas and I want to add a gas stove. The black pipe gas line is accessible in the area where I want to put the stove. I would like to cut the pipe in 2, add a T joint and then run the new T section to my gas stove. Question, how do I cut it and add a T joint? I checked with the city and I do have the capacity on the line to add the stove. Thanks
johnrh is offline   Reply With Quote
Old 04-07-2010, 04:37 PM   #2
hhm
You should probably have a hardware store or Lowes cut and thread a couple sections of black steel pipe and or go with some nipples and a union. Length has to be perfect on the second option though.
hhm is offline   Reply With Quote
Old 04-07-2010, 05:38 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
If you are asking this question, I think you need to undertake an easier DIY plumbing project than gas pipe fitting. In most jurisdictions this work would require a permit and a license.
A leak in a water pipe can get things wet, a leak in a gas pipe has much bigger ramifications.
Also, how could the city know you have enough capacity without an inspection. They may be saying your incoming gas service has enough capacity. But does the pipe you are trying to tap have enough capacity?
Coastal South Carolina
Old 04-07-2010, 06:36 PM   #4
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Add gas stove
CALL A PROFESSIONAL PLUMBER !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Tags
black pipe gas install
3 wire stove connection bgoldie Electrical 13 03-01-2011 12:29 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Wood stove ? econdave General DIY Discussions 8 10-17-2007 06:50 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
