Gas Shutoff For Fireplace - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2010, 09:55 PM   #1
Question
Gas shutoff for fireplace
My new construction home has 3 fireplaces. All 3 have a shutoff valve located within 6' of the fireplace, all the same type - requiring a key to be inserted to turn the valve. For one of them, the shutoff is inside of an adjacent cabinet and not in plain sight.
The city inspection report (done before i purchased the home) says 'gas shutoff in downstairs fireplace'. I wasn't sure what this meant since all 3 have a shutoff valve. When I emailed the supervisor at the city he responded that the shutoff 'is not an allowable one. This type requires a “key” to open it which defeats the purpose of being able to shut it off in an emergency in the event the “key” is missing'.
I have never heard of this. Is there some other type of shutoff that needs to be installed within 6' of the fireplace in addition to the key?
Any advice would be very much appreciated....
WishIWasAPlumbr is offline   Reply With Quote
Old 02-16-2010, 10:31 PM   #2
Rewards Points: 1,016
Requirements can vary city to city. That said, I just recently finished a major remodel that included the installation of a three sided fireplace - with a gas valve that requires a key. All was inspected and it was not an issue.
Old 02-17-2010, 07:28 AM   #3
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
That is correct each city can have their own little codes. I just need one for each item where it t's off the main.
Big N8 is offline   Reply With Quote
Old 02-18-2010, 07:29 AM   #4
Code or no Code common sense here if I had a gas fireplace that had a shutoff that needed a key I would permanently attach a key to it somehow or I would have a backup valve to be able to shut off fast no key.
I am not saying don't follow codes but go even one better. Just think about what you would do in an emergency. Thats all.
PS: I would also make sure everybody in the house knew where the valves are and what to do in an E.
SULTINI is offline   Reply With Quote
Old 02-18-2010, 08:35 AM   #5
your valve cannot be concealed in a cabinet
The older I get the better I was
Old 02-18-2010, 08:52 AM   #6
I second that
Old 02-18-2010, 01:21 PM   #7
I agree the cabinet thing is a problem, and I'm willing to move it out of the cabinet.
My confusion is that the inspector says the key-type valve is not allowable. I've never seen any other type of gas valve in a woodburning fireplace with a log lighter - i think they are installed that way to prevent it from being turned on by a child, etc.
I've emailed the inspector and asked him to clarify what an allowable type is, or if multiple shut-offs are required.
Old 02-18-2010, 02:04 PM   #8
It should have a Pilot light or electronic ignition safety built in that even though the main gas valve supply is open the safety circuit is still in play.
There are tamper proof gas valves that kids can not operate but can be operated by adults by pushing a spring type lock and moving the control handle. Can not remember the company or name it's been a while back.
Old 02-20-2010, 09:00 AM   #9
Just to set the record straight, that valve is a "service" shut off, not an "emergency" shut off. If you have an emergency, you need to evacuate your family and turn off the gas at the meter.
log_doc_rob is offline   Reply With Quote
Old 02-20-2010, 09:05 AM   #10
Licensed Master Plumber
Does the valve need a key or has the handle been removed to gain clearance? Either way, the gas valve must be at the appliance, on the same floor ( not beneath the floor ) and readily accessible. National fuel gas code.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-20-2010, 09:17 AM   #11
Were talking semantics here log--doc. I think everyone knows what the situation is and the valve were talking about.
Common sense dictates get out immediately. Most people don't even know where their gas meter is and don't have the right tool to shut it off.
I know that for a FACT.
Old 02-20-2010, 10:00 AM   #12
I agree that common sense is not common.
That valve is there so you can isolate it from the rest of the gas system so you do not have to turn off gas to the entire home when repairing that appliance. While it is quite apparent to professionals in the gas industry, this is a DIY site and most are not pros and they need to be properly educated.
It is quite common in my area for the isolation valve for gas fireplaces to be placed in a cabinet or it is a keyed valve placed in the wall or floor.
Old 02-20-2010, 01:57 PM   #13
I agree however if that is the only valve most people associate with the fireplace they would use that as a Emergency Shutoff/ or Just Shutoff.
Not the main at the meter. They would leave that to the Fire Dept to shutoff.
Old 03-07-2010, 11:36 PM   #14
Here in TN the key valve shutoff has to be within arms reach of the fireplace opening. Now what equals arm length is up to the inspector I guess.
ausblake is offline   Reply With Quote
Tags
gas fireplace
toilet shutoff valve not getting water JackyS Plumbing 4 11-23-2009 08:29 AM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 07:38 AM
Meter Shutoff Ultrarunner2017 Plumbing 14 03-18-2009 08:29 AM
Water shutoff questions robwallis Plumbing 1 02-09-2009 04:22 PM
Need your help installing a shutoff valve! HELP! HELP! kevp Plumbing 6 12-21-2008 12:36 AM
