Gas Reducer Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 08:58 PM   #1
Rewards Points: 99
Gas reducer fitting
Was force to go to lowes to get a 1/2 female to 3/8 male reducer in order to adapt natural gas to my grill. The hose from the grill screws into the 3/8 male thread and the 1/2 female would screw into natural gas coming from house. The reducer seems cheap, actually same material as the end of a garden hose. I installed this reducer an no leaks detected. My question is, should I install a cast iron reducer? Just not sure if the piece I install will do? Thank you all in advance!!
er78mph is offline   Reply With Quote
Old 02-24-2013, 09:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 806
Did it say if it was gas approved on the packaging? You could use a black iron bell reducer.
Can you upload a picture? Perhaps someone can verify its use.
Old 02-24-2013, 09:12 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Can not be a bushing must be a bell, and not that Sh%t from china.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 09:23 PM   #4
Rewards Points: 99
Did not say any on packaging, just said it was a reducer. At this point, I just want to have the right piece.
Old 02-24-2013, 09:31 PM   #5
Rewards Points: 13,994
Without a picture or a web site how would we know what you have.
It should have looked like this or black iron, no galvinized.
http://www.bing.com/images/search?q=...electedIndex=0
Also needed yellow pipe tape or gas approved pipe dope.
Old 02-24-2013, 09:34 PM   #6
Rewards Points: 99
Piece currently install, no pic now but thanks!!
Old 02-25-2013, 07:12 AM   #7
MarginallyQualified
Rewards Points: 2,464
Do you have a valve out there as well?
Old 02-25-2013, 07:34 AM   #8
Rewards Points: 99
Yes, shutoff valve
Old 02-25-2013, 09:32 AM   #9
Rewards Points: 99
Is this reducer the correct one? I sil be shutting off gas after every use, thank u all!!
Old 02-25-2013, 09:37 AM   #10
That's fine.
There is a flex line from the fitting to the grill, right?
Old 02-25-2013, 09:46 AM   #11
Rewards Points: 99
Not a flex line Joe but a natural gas hose from conversion kit that I bought. Thanks again!!
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
