Old 11-14-2008, 05:11 PM   #1
Question
Gas Range
I just finished installing a new gas range, this was a replacement of an older range.
All the fittings are good, tested with leak detector, all seems well. I was not the person who installed the first range and now when I moved this range back into place the copper gas line is resting on the backside of the range. Should I be worried?
Thank you for your advise
cookiemom1970 is offline   Reply With Quote
Old 11-14-2008, 05:58 PM   #2
bradnailer's Avatar
Gas Range
Just my opinion but you should never use copper for gas service. Other than that, it shouldn't be a problem.
bradnailer is offline   Reply With Quote
Tags
gas lines, new appliance, oven, range
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about diagnosing coolant leaks. You may first notice a coolant problem because your car is over heating or running a lot harder than it should. The first thing you want to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be diagnosing our problem. We have a bathroom here that is set up with an older style faucets, now over the years this faucet has develop a leak which has gotten progressively worst... Read More »
About Engine Coolant Leaks
About Engine Coolant Leaks by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about common coolant leak points. There are several common coolant leak points. First you want to check the coolant overflow reservoir for cracks or leaks around the hose... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how do I fix a coolant leak. There are a lot of products that you can add to the coolant which will help seal small leaks in your coolant system. However if... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question “Is my coolant still good?” The first way to test if your coolant is still good is through a visual inspection, so go ahead and take a look in... Read More »
range hood through the wall - - -stud in the way pacifier1er Building & Construction 27 03-04-2009 09:33 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 05:43 PM
3 prong range? laduehelp Electrical 39 03-11-2008 02:33 PM
gas range swap kenny11876 Appliances 2 02-20-2008 09:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
