Gas Poly Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2011, 10:19 AM   #1
bradnailer's Avatar
Gas Poly Pipe
I've searched this forum and google and haven't been able to find anything current. I need to run a gas line from the water heater to the kitchen range. What is the latest on using gas poly piping inside a home and installation by a homeowner? I can run black pipe but thought I would look at other options. Thanks in advance for the help.
bradnailer is offline   Reply With Quote
Old 10-13-2011, 07:14 PM   #2
Plastic pipe for gas is only approved for underground installations. As for whether you can install gas lines as a homeowner, that is a question for your local gas regulatory body, as it varies by location.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
Alan (10-13-2011)
Old 10-13-2011, 08:35 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
Some things are just not work taking the chance on....biggest issue is someone driving a nail into a wall and putting a hole in the poly gas line.....
One of the reasons I'm doing copper in the 2-story addition of my house.....my wife loves to hang her paintings.....why take a chance on one of her nails going through a piece of PEX.....
Old 10-13-2011, 08:39 PM   #4
Plus, it's completely against code.
Old 10-13-2011, 08:56 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No POLY gas pipe in the house, and personally I don't like the stuff at all. If the warehouse mistreated it before they gave it to ya, and you happen to need to put one of their (really expensive) o-ring fittings right where there's a nick or even a small scratch on the outside of the tubing, you're never going to get it to stop leaking.
Journeyman Plumber
Old 10-14-2011, 09:12 AM   #6
bradnailer's Avatar
Thanks for the responses. Black pipe it is.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
