Gas Plumbing- Materials To Use Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2013, 09:19 PM   #1
Gas plumbing- materials to use question
I am doing my backyard and I wanted to put in gas lines for tiki torches, grill station and potentially a patio heater or two. I realize I cannot do gas work myself so I have had two plumbing contractors out to give me a price.
One guy is recommending running galvanized pipe, the other is recommending PVC with some other material running through it. The second guy also mentioned poly but said it was way to expensive.
My question is what materials are recommended for a project like this- it will be run under a concrete slab with 1.5 inch blue stone on top? I do not know much about gas but want to make sure this is done right.
Thank you in advance for your responses!
AWW NJ is offline   Reply With Quote
Old 06-09-2013, 08:23 AM   #2
Rewards Points: 2,516
After receiving the info from how the plumbers want to do this, call your gas supplier and get their input.
hammerlane is offline   Reply With Quote
Old 06-09-2013, 08:28 AM   #3
Makes sense. I will give them a call tomorrow and get there input. Thank you
Old 06-09-2013, 08:37 AM   #4
Post back what they tell you if you dont mind
Old 06-09-2013, 12:29 PM   #5
Rewards Points: 1,770
The Gas supplier makes the call on what materials they will allow to be used.
Old 06-09-2013, 01:19 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
PVC? Even if allowed I would not use it....especially outside....black pipe only for me....
And why can't you do your own work? Oh....you must be on the East Coast....
Old 06-14-2013, 04:46 PM   #7
There's a saying - it's better to do it right the first time around. Go with the galvanized pipe. Though it's more costly it will last the longest and give you less trouble in the long run.
____________________
Don't Kill the Dream, Execute it.
http://fhfurr.com
Retroloco-LJ is offline   Reply With Quote
Old 06-14-2013, 05:14 PM   #8
Oso954's Avatar
Rewards Points: 746
You should also know what you are talking about before giving advice. Just because it may be OK where you are, does not mean it can be used everywhere.
Some jurisdictions prohibit galvanized pipe.
Some gas suppliers prohibit any galvanized pipe, even on your side of the meter.
The right advice is to check with the gas supplier or the local authority having jurisdiction.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
FClef (06-14-2013)
Tags
gas , gas tiki torches , patio heater , plumbing
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
Basic Question on plumbing (planning to unclog bathroom sink drain) babyfishmouth Plumbing 1 07-31-2011 01:14 AM
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 12:50 PM
Plumbing access door question Branden Plumbing 10 11-08-2010 03:18 PM
Time & Materials question Peter714 Building & Construction 4 12-01-2009 12:32 AM
