Gas Piping Thru Cinder Block Foundations - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2013, 07:42 AM   #1
biggles's Avatar
gas piping thru cinder block foundations
this was a length of pipe from the gas meter running into a crawl space after 40 years of road traffic and salt water I removed it,and used a PVC sleeve (thru foundation) then slipped the new piping in from the meter..failed a National Grid standing test on the meters lowest 1/2 FT dial movement within 10 minutes.
Old 07-13-2013, 07:53 AM   #2
biggles's Avatar
to do a standing test shut the valves at all your items that use gas then shut the valve at the meter coming out of the ground....black magic marker....mark the 1/2 ft needle and let it stand for 10 20 minutes...if the needle is still covered by the mark your lines are tight...if you see the needle you might have a slight leak.if your adding a BBQ or moving stuff around it is a good way to test the repipe...spray bottle with dish liquid soap mixed with water is the norm
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Leak in the cinder block foundation. 68MHJCs Building & Construction 7 01-25-2008 10:37 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
