Gas Pipe Supports - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2011, 08:00 AM   #1
Gas pipe supports
I'm going to be replacing 3/4" gas line entering the house from the meter.
Is the proper support method to ~
Secure tightly to floor joist with metal strap/clamp.
kevsprojects is offline   Reply With Quote
Old 09-09-2011, 09:01 AM   #2
Plumb or Die!
That works, use copper strap if it's copper pipe, though. A gas repipe isn't something I'd normally suggest for a DIYer.
plumber666 is offline   Reply With Quote
Old 09-10-2011, 06:01 AM   #3
I hear ya ~
I did a complete replacement and added a new line for a stove about 12 years ago at a previous residence. I used black iron pipe and pipe dope/threading compound. I would go with black iron pipe again for the rigidity quality, around here its what home buyers like to see. What is the correct threading agent though, something called "Blueloc" ? I just need an update as to what to use for the threading sealant.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
