Gas Pipe - Limitation On Location? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 09:59 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Gas Pipe - Limitation on Location?
Are there any limits on where you can run gas pipe?
In other words....can I run it in a false ceiling to get it over to a laundry room?
Old 05-04-2012, 10:28 PM   #2
Rewards Points: 6,652
Depends on your local. They run in false ceilings in places like Micky D's, Burger King, Taco Bell, KFC, etc, so why not in a house.
Old 05-04-2012, 10:31 PM   #3
Rewards Points: 636
you can here just need to keep it protected and hung correctly.
here is a link to what i use it is special shielded flex line
http://www.gastite.com/products.php?...2&idlink=link3
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-04-2012, 10:35 PM   #4
I don't think gas code allows unions or valves to be closed in. Other than that you can run gas lines in false ceilings. Check your local code.
sanec1 is offline   Reply With Quote
Old 05-05-2012, 09:15 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 990
Different materials different installation requirements by code. Gas work is best left to licensed contractors that pull permits and have the work inspected.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-05-2012, 09:57 AM   #6
Not every place requires permits or inspections for gas line installs.
Old 05-05-2012, 10:06 AM   #7
Experienced
Jackofall1's Avatar
I don't see drop ceilings in this
SECTION 404 (IFGC) International Fuel Gas Code PIPING SYSTEM INSTALLATION
404.1 Prohibited locations.
Piping shall not be installed in or through a ducted supply, return or exhaust, or a clothes chute, chimney or gas vent, dumbwaiter or elevator shaft. Piping installed downstream of the point of delivery shall not extend through any townhouse unit other than the unit served by such piping.
But this is only (1) code of many.
The Following User Says Thank You to Jackofall1 For This Useful Post:
ddawg16 (05-05-2012)
Old 05-05-2012, 03:26 PM   #8
JOATMON
ddawg16's Avatar
I have permits for all the work on my 2-story addition.....and I'm doing all the work myself....every single nail.....every single pipe.....you can see the progress so far by clicking on the "2-Story Addition Build" link in my signature.....
As for doing the piping....it's about one of the easiest parts of my addition....and yes, I know how to thread pipe.....and yes, I know not to use unions or valves in inclosed spaces....the only valves will be at the POU.
My existing house has a crawl space and all the gas plumbing is down there. Where I need to go in the addition, the most direct route is through a drop ceiling that I will have in the downstairs bathroom...
Old 05-05-2012, 03:43 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 452
You should have no problem doing this.
I assume you have sized the new line as well as the capacity of the existing piping. Can it handle the the added demand?
How about testing? Do you have a plan?
I'm not asking these questions because I doubt your ability- just want to help.
Old 05-05-2012, 03:55 PM   #10
JOATMON
ddawg16's Avatar
I'm ok on capacity....as long as I keep the lines 3/4" most of the way.
Main Forced air heater is 60K BTU, water heater about the same....gas stove top uses almost nothing...gas dry about 25K BTU (I think) and then a gas fireplace upstairs....60K.
I did some quick calcs based on 'the internet'....because my runs are not that long from the source and branch out....I should be good....I believe my gas pressure is 5" or about 0.2 PSI. If need be, the gas company will crank it up.
As for testing....when done, I'll close off all the POU valves, break the line loose at the meter and pump it up to about 20 PSI and leave it blocked with a gauge on it over night....leaks are not allowed in my house.
Old 05-05-2012, 04:09 PM   #11
Plumber
Rewards Points: 452
One word of caution- disconnect your supply lines from the valves and cap or plug the valves. If any of the valves do not have 100% shut off you'll be putting your test pressure against the appliance which are not rated for that.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
drain pipe location davemarz Plumbing 1 04-30-2011 09:34 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
