#1 |
Gas pipe in Garage
I need to run a new gas pipe to install a tank-less water heater. There is a 3/4" pipe there now that is 24" off the floor, but I need to upgrade to 1 1/4" pipe. The pipe will need to run across the wall opposite the garage door entrance. If I run the pipe up high along the header will I have to install safety posts to meet code?
#2 |
Gas pipe in Garage
Anyone?
#3 |
Doing it myself
Gas pipe in Garage
I'm assuming you've looked at the code since you're asking this question. It seems to me that if it's not in an area where it could be damaged by a vehicle, it would be just fine. The code is open to interpretation by the inspector though. You might be better off asking him what he wants you to do.
Journeyman Plumber |
#4 |
Gas pipe in Garage
I would say if it was higher than the garage door you should be all set.
No additional protection needed. |
| Display Modes | |
| How to stop sump pump discharge pipe freezing??? | relbeig | Plumbing | 8 | 11-12-2012 01:03 PM |
| Best way to join Poly pipe, for a water pipe repair. | carl1864 | Plumbing | 9 | 08-21-2011 03:17 PM |
| Cover Up Soil Pipe in Garage? | mark2741 | Plumbing | 4 | 10-20-2009 10:29 PM |
| advice on cold water pipe in basement garage area | cambie | Plumbing | 6 | 10-15-2008 02:29 PM |
| Waste pipe odor in garage? | Kirsten | Plumbing | 3 | 11-21-2006 01:07 PM |
