Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2006, 04:51 PM   #1
Gas Pipe
Hi all,
Can you tell me if I can only use black pipe for gas? I've heard that galvanized pipe is now alright to use too. I live in Chicago, and am curious. I heard a plumber in the hardware store say the either one is okay.
Thanks,m this is a helpful place.
Talman48 is offline   Reply With Quote
Old 02-22-2006, 07:30 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Depends on your local code.
I grew up in the East Texas oil field, and there were a lot of homes with galvanized pipe (with pipe joint compound on the fittings) for natural gas.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-23-2006, 12:43 AM   #3
Originally Posted by Talman48
Hi all,
I believe that is correct. I've been following a discussion on another forum and it seems the consensus is that galv is ok even though most of the guys thought it was not. i spoke to one of our plumging/ mech inspectors tonight and he said galv is ok here and I have never seen anyone use it. He also said tin line soft copper is allowed and i have never seen anyone use that in this area. He also said nat gas has varying moisture content depending on the supply and that ours is dry and never a problem with galv.
Flexible stainless with the yellow jacket is allowed but you have to be certified by the manufacturer.
He told me to check the International Gas code for allowable pipe. HS..
K2eoj is offline   Reply With Quote
Basement Rough In Advice Needed mikemille Plumbing 5 02-18-2007 09:55 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
