Gas Meter Plug - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2012, 07:08 AM   #1
gas meter plug
After a fire restoration in our home I am trying to light our gas FP (the only gas appliance we have) and find there is no gas coming to the FP. The gas is on at the meter. The plummer tells us that there is an installed plug in the meter that blocks gas from entering the house and he doesn't have a tool to remove it, but the gas company says they have not plugged the meter. I assume it may have been plugged at the time of the fire by the remodeling people or the fire dept.. How do I remove this plug?
fordeject001 is offline   Reply With Quote
Old 01-20-2012, 07:30 AM   #2
Rewards Points: 1,214
Contact the fire DEPT, the local code DEPT and the gas Company. They will have the answers not the internet on this one.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
plummen (01-20-2012)
Old 01-20-2012, 08:44 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 984
Itís a puck, gets put in to a union just after the meter, you canít see it unless you pull the union apart better let the gas company look for it. If thatís what they used.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-20-2012, 02:37 PM   #4
Should be red tagged and locked.
ben's plumbing (01-20-2012)
Old 01-20-2012, 07:52 PM   #5
calling doesn't work
I called the gas company and without looking they just tell me there is no plug in the meter, but the plumber for the restoration company tells me there is, but he never left the house to reach this conclusiuon. I have gas going into the meter, no visible shutoff between the house entry and the FB, but still when I pull the line at the valve to the FP, I have no gas.
Looks like I will just have to live without a FP.
Old 01-20-2012, 08:15 PM   #6
Call the gas company and tell them that you don't have gas. They'll at least have to verify that they have gas leaving the meter, and while they're doing that, they can see if your meter has been, in fact, plugged. It could even be an obstruction before the meter, it doesn't happen very often, but it does occasionally.
hvac benny is offline   Reply With Quote
Old 01-20-2012, 08:38 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Does the gas company have another shut off at the street?
Could there be another shutoff someplace in the basement that got turned off?
plummen is offline   Reply With Quote
Old 01-20-2012, 09:16 PM   #8
Rewards Points: 582
plummen makes a good point thought when there is a fire at a location all utilities are cut to property and gas is shut off at street????
Old 01-20-2012, 09:22 PM   #9
plummen's Avatar
Some areas have a stop box for the gas out by the sidewalk or street like a water stopbox if you have an old gas meter in basement
Old 01-20-2012, 09:26 PM   #10
Rewards Points: 582
yep most have curb boxes....
Old 01-20-2012, 10:02 PM   #11
Not where I live. Only commercial customers have a curb cock (I refuse to be PC and call it a curb box or curb stop ).
The Following User Says Thank You to hvac benny For This Useful Post:
Water Meter Out of Control cdeliopo Plumbing 16 01-08-2012 11:08 PM
Drop Wire (From Weatherhead to Meter) roadman1977 Electrical 7 12-24-2011 12:35 PM
Can I use a piece of wire to connect a grounding plug to an outlet? Smoked Electrical 9 10-14-2011 04:56 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 07:00 PM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 09:26 AM
