Gas Load Data - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2009, 09:47 AM   #1
Gas Load Data
I need help with estimating Gas Loads. I currently have three residential buildings that I heat with Oil, and I am looking to convert to gas. I need to estimate the BTUs required for each unit.
Unit # 1 is a 4000 sq mother daughter which has HWBB Heat, 2 stoves one dryer and 1 Heatmaker attached to the furnace
Unit # 2 is a 2000 Sq 2 family with HWBB heat, 2 stoves and 1 dryer and an elect HWH
Unit # 3 contains 3 one bedroom apartments w/ HWBB heat and a heatmaker on the furnace. There are a total of three stoves.
Is 1/4 PSIG ok for what I am doing?
Can someone give me a formula that I can use to estimate the load properly? Thanks
AJ&J is offline   Reply With Quote
Old 03-26-2009, 10:24 AM   #2
HVAC / Plumbing
You will have to obtain the BUT'S from the appliances... gas stove burns xxxx btu ..gas dryer burns xxx BTU'S etc
kenmac is offline   Reply With Quote
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Load Calculation ? RM575 HVAC 9 07-04-2007 12:37 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
