Old 10-02-2012, 10:38 PM   #1
Gas lines in walls
Old gas wall heater was apparently removed from this bathroom. We are remodeling and found the capped off line in the wall.
Is this ok or should it be removed and capped in the attic?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 10-02-2012, 11:32 PM   #2
JOATMON
ddawg16's Avatar
Gas lines in walls
If your in there.....and your sure that there is no chance you will use it....I would remove all the sections that you don't need.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-03-2012, 12:05 AM   #3
Persona Non Grata
VIPlumber's Avatar
Gas lines in walls
Is this line hooked into the rest of the system? If so, it's always a bad idea to leave a terminated/capped line inside of wall. The next person might not be as careful/lucky as you when remodeling.
Take back to the attic or other safe, but accessible location. Ball valve and cap the end of the line.
VIPlumber is offline   Reply With Quote
Old 10-03-2012, 12:07 AM   #4
Gas lines in walls
Thanks guys.
Old 10-03-2012, 07:44 AM   #5
Gas lines in walls
yep do exactly that.... ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-03-2012), digitalplumber (10-03-2012)
Old 10-03-2012, 02:37 PM   #6
Gas lines in walls
Is the ball valve code or absolutely necessary?
Old 10-03-2012, 02:43 PM   #7
JOATMON
ddawg16's Avatar
Gas lines in walls
No necessary....but it means that if you want to add something in the future using that stub....you don't have to turn off the gas to do the work.
Case in point....over the past month I have turned off my gas about 6 times to finish up the gas lines in my 2-story addtion....I really wish I had installed a ball valve going to the addition....it would allow me to isolate that section and keep gas to the water heater and kitchen going.....
Translation...the wife would have been a lot happier....
My
and
Old 10-03-2012, 02:47 PM   #8
Gas lines in walls
Thanks, this line and actually the one in the bathroom down the hall, before this room, are on a branch off of the main gas line that will never be used again.
Thanks.
The Following User Says Thank You to digitalplumber For This Useful Post:
ben's plumbing (10-03-2012)
Old 10-03-2012, 08:18 PM   #9
Gas lines in walls
Remove the pipe all the way back to the main and cap it or plug it using the proper dope, don't forget to leak check.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is online now   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (10-03-2012), digitalplumber (10-03-2012)
Old 10-03-2012, 09:21 PM   #10
Gas lines in walls
Thanks.
in that case cap it off
COLDIRON (10-04-2012), digitalplumber (10-03-2012)
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 08:05 PM
Flexible gas lines behid walls, up to code? gante Plumbing 8 03-27-2009 04:18 PM
