Gas Line Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2013, 03:48 PM   #1
gjr
gas line size
I would like to install a naturl gas generator Generac 5471 (10 kW) at approx 60 ft from the gas meter.Which size of pipe do I need and should i upgrade the gas meter( to which size) ?
Thank you for your help
gjr is offline   Reply With Quote
Old 03-07-2013, 05:29 PM   #2
Rewards Points: 252
I can only speak of my generac generator that I had installed a couple years ago. The plumber used 3/4 inch black steel pipe with an indoor shutoff. He also recommended I call the gas company and tell them I have HW heater, boiler, back-up generator, and gas stove that may all possibly be running at the same time. Gas company came out and told me I needed to upgrade gas meter, which they did at no charge. They will tell you what size you need. I don't know your location, but in upstate ny we have National Grid. Everything runs great. How many appliances do you have using ng? You probably will need gas meter upgrade as well.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
gjr (03-08-2013)
Old 03-07-2013, 05:34 PM   #3
Rewards Points: 1,878
You also need to make sure you have an automatic way to disconnect your house off the electric grid. Otherwise you may fry some poor line man working on the wires.
The Following User Says Thank You to Ghostmaker For This Useful Post:
jmon (03-07-2013)
Old 03-07-2013, 06:33 PM   #4
Rewards Points: 6,652
Your local gas utility would be able to tell you, once they know all of the info. Best to contact them regarding this.
The Following User Says Thank You to gregzoll For This Useful Post:
jmon (03-07-2013)
Old 03-07-2013, 06:34 PM   #5
The Generac install comes with all of that.
jmon (03-07-2013)
Old 03-07-2013, 07:42 PM   #6
Rewards Points: 252
GM, excellent point. The electrician, who did the wiring, also explain that same statement to me. By code, it has to be wired that way.
Old 03-08-2013, 12:25 PM   #7
gjr
Gas line
Thanks jmon
Location Long Island
Gas supplier National Grid
I have HW heater, boiler, range top(only) not oven,and gas fireplace
Piping adequate for above
National Grid does not want to come and recommend size of meter.
Says up to the plumber to decide.
Pipe to generator will run directly to Generator not added to the other piping
Do you know size of your meter : 250 or 400 ?
regards
Gilbert
Old 03-08-2013, 05:34 PM   #8
Rewards Points: 252
yea, I'm in saratoga county. They may have changed procedures. I believe I had a 250, and they upgraded me to 400. I'm at work right now, I will check tonight let you know for sure. Check after 8pm.
Old 03-08-2013, 07:00 PM   #9
Rewards Points: 966
I called my gas utility today and they told me I had 250,000 btu capacity.
I am getting the 8kw that requires 140,000 btu. With my 80,000 btu furnace and 40,000 btu water heater I am a bit over, but don't expect to use it anywhere near full capacity.
(IIRC the 10kw is 155,000 btu)
My installer is using 1" pipe, but I am only 4' from the meter. I don't really know if your 60' would require more.
Toller is offline   Reply With Quote
Old 03-08-2013, 08:17 PM   #10
Rewards Points: 252
gjr,
That's affirmative my gas meter says 400 on it. That'll give you 400,000 btu capacity which will be more than enough to run everything you got all at once. The reason they want a master plumber to confirm it, is that the 400 flow meter is a bit more expensive than the 250 flow. NG came out and upgraded me at no cost. Well, that's not entirely true, I do pay monthly utility rates which are outrages here. My deliver cost (just for having gas and electric delivered to my house) is double what I actually use. Oh well, that's a story for another time. Hope this helps.
Old 03-09-2013, 03:05 AM   #11
would you rather the delivery charge was hidden in the gas bill?
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
jmon (03-09-2013)
Old 03-09-2013, 09:08 AM   #12
Rewards Points: 252
Roger that hvac benny. At least they are up front about. People have to be paid and maintenance has to be done on lines, etc.
Old 03-09-2013, 10:13 AM   #13
An old Tradesmen
Rewards Points: 6,962
When your HWH is on and your furnace starts to run, your gen will kick up, and you may notice it lagging.
Old 03-09-2013, 04:06 PM   #14
To size gas pipe you need to know length of gas utilities from meter and buy rating for each one in order to size the pipe you need.
joes plumbing is offline   Reply With Quote
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Suction line size kogashuko HVAC 5 07-07-2011 10:27 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 12:50 PM
