Old 12-31-2011, 07:55 PM   #1
gas line rough in height for dryer and stove?
Is there a height that the gas line nipple should exit the wall above finished floor?
If there's not a required height, is there a general guideline?
graysqwrl is offline   Reply With Quote
Old 12-31-2011, 08:03 PM   #2
Main guide line is DIY's should never install gas lines. Hire the gas company or gas certified plumber. It requires a special licence.
Old 12-31-2011, 08:14 PM   #3
well... seeing as I already re-did the main line, the line to the water heater, furnace, and fire place I'm kinda in the thick of it
So, I've run all the way to where the stove and dryer will go... just wondering if there's a specific termination height I should be aware of. Or minimum/max height.
Old 12-31-2011, 08:21 PM   #4
we set gas valve for dryer about 40" off floor....and as far as stove...if up through floor which i suggest about 2" from wall....if it comes out of wall we come up 3" off floor...ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (12-31-2011)
gas stove line tomcatcardona Kitchen & Bath Remodeling 1 11-14-2011 08:18 PM
Small H2O line running up woodburing stove mibson HVAC 3 01-22-2011 10:14 PM
gas stove line koleen Appliances 4 01-07-2011 03:16 PM
Flare unions and pipe dope when installing gas stove line BrainDoc Plumbing 1 09-11-2010 11:42 AM
Stove Gas Line mrlloyd Appliances 1 04-23-2009 05:41 AM
