Gas Line @ Pool Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2012, 07:45 PM   #1
gas line @ pool heater
The gas line @ ground level rotted. It does not have any elbows 11'' down but bends and goes under the pool heater. Do I have to cut the pipe and thread it? It is galvinized pipe.
Raddman3355 is offline   Reply With Quote
Old 04-18-2012, 09:50 PM   #2
Rewards Points: 14,026
#1 The gas company should be doing this not a DIY.
#2 Galvinized pipe should not have been used for a gas line.
The whole line needs to be run with copper.
Old 04-19-2012, 04:25 PM   #3
Rewards Points: 1,300
In my area the gas company will not touch anything on the customer side of the gas meter. It is up to the customer to make or arrange for repairs.
Someplace along that pipe there should be a connection. My concern would be if the pipe started leaking in one place it will most likely do the same in other places as well. May be time to replace the whole line.
danpik is offline   Reply With Quote
Old 04-20-2012, 06:11 AM   #4
Rewards Points: 1,216
Replace the entire line with approved material rated for gas service.
COLDIRON is offline   Reply With Quote
electric hot water heater in line with DHW coil from boiler bubbler Plumbing 9 04-09-2012 09:43 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
Inground Pool Leak - suggestions needed hravenkel Plumbing 10 03-21-2011 08:39 PM
Pool heater is dead. Replacement recommendations? Big Top Gt General DIY Discussions 0 03-02-2011 11:48 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
