Gas Line, Left/right Or Union - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2009, 11:42 PM   #1
gas line, left/right or union
we are modifying a duplex to turn a small closet into a laundry area. in doing this we need to tap into the existing gas line to add a tee that will supply the gas dryer (yes we have sufficient intake air), but i would like to know if we can use a 3/4 union to attach old and new lines, or do i need a right/left nipple to be code compliant.
Thanks! Steve
Steve Burke is offline   Reply With Quote
Old 09-09-2009, 12:11 AM   #2
Registered User
Termite's Avatar
Unions can be used as necessary but they're required to remain accessible. Can't conceal them in walls and floors.
Old 09-09-2009, 08:49 AM   #3
Excellent and thank you.
Does anyone have advice on the best way to terminate a gas valve for the laundry area? A pipe going out the wall with a 1/4 turn valve is a bit rustic. I am wondering if there is a gas housing something like the water/waste housing for the laundry supply, or the nice little water on/off housing for an ice-maker.
Old 09-09-2009, 11:53 PM   #4
Registered User
Termite's Avatar
Sure do. These just hit the market and they're pretty slick. They're new enough that you might need to go to a plumbing supply house for them....I doubt the box stores will have them. Sioux Chief just mailed me the literature on them late last week.
1/2" and 3/4" NPT pipe thread versions are available for threaded gas pipe.
http://www.siouxchief.com/Access/Out...s-Ox-Box.XQ96F
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
PVC line on natural gas line for BBQ Nikroo Plumbing 28 05-13-2009 09:01 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 12:40 PM
Gas line union installataion diggerdave Plumbing 5 02-14-2009 12:59 PM
