Gas Line Into Fireplace - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2009, 03:32 PM   #1
Gas Line into Fireplace
50 yr old home, incoming gas line to fireplace is not round and is stripped. Have approx. 2 to 3 inches remaining vertically thru concrete floor of firebox. In order to reinstall 90 degree elbow, is it best to hire someone to rethread or are there other solutions? Is there enough vertical pipe remaining that it can be cut and rethreaded? Thanks
Wingingit is offline   Reply With Quote
Old 02-22-2009, 06:16 PM   #2
Registered User
Termite's Avatar
It would be pretty much impossible to re-thread it while still installed in the fireplace, especially with only 3" protruding. What do you mean it is not round? Is it somehow deformed? Provided you can get to it without tearing up the firebox, my recommendation would be to replace the pipes instead of trying to re-use/re-fit them.
Old 02-23-2009, 01:25 AM   #3
gas line into fireplace
Thanks for reply. yes, the vertical pipe is also deformed, cannot seal properly with any cap or elbow that would require threaded connection. Is welding by a pro a possibility? The floor of the firebox is brick, the pipe extends thru the motar separation. If I drill thru the motar, around the vertical pipe, do you think there is a possibility I will be able to put a wrench on the pipe and loosen it from the connection below the brick surface of the firebox? Thanks again
Old 02-23-2009, 07:26 AM   #4
biggles's Avatar
if you can get the wrench on the last elbow before it goes vertical below the brick.........then a wrench on the piece of riser pipe right at the threads and that last elbow(below the brick).remove it go to HD,and get another piece cut and threaded .add a couple of inches going into the fireplace if you need it.
Old 02-23-2009, 08:58 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,288
How do you check for leaks in this situation?
Edit, nevermind... Answer: Pressure test with air.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-23-2009, 09:30 AM   #6
Registered User
Termite's Avatar
If threading the pipe becomes problematic, then it might be possible for the pipe to be welded. It depends on the condition of the pipe. Welded joints are commonplace in commercial construction but are never seen in residential (read: get ready to pay through the nose). The problem with that is that you'll need a 60psi airtest on a weld, which could force a leak on a threaded connection elsewhere in the system.
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
