#31 |
Gas Line Extension - Can I use Flexible Pipe?
you shouldn't be. Being that it's tied to the main gas line, you shouldn't re ground it (assuming the original gas line is properly bonded). From what i've been told though, the rubber insulated gas line is still not impervious to lighting.
#32 |
This is sort of laughable that people would be running a flammable substance through an easily to puncture pipe. Unbelievable. I have heard that flux eats pinholes in this stuff. The problem is plumbers that run black pipe can not compete with guys running this playtime gas line. Seems everyday I hear more and more stuff about how the world is going. I am just really out of touch these days.
#33 | |
Gas Line Extension - Can I use Flexible Pipe?Quote:
| The Following 2 Users Say Thank You to hvac benny For This Useful Post: | a_lost_shadow (10-13-2012), plummen (10-13-2012) |
#34 |
ok...so after further inspection of this flexible gas tubing, I see that it's a flexible metal tube (very similar to the yellow flex tubing) that is then covered in a thick rubber. I would assume that the rubber would reduce the conductivity if my house were to be stuck by lightning. However...after the house explosion (flattening!) in Castle Rock last week, I'm definitely worried now. Wish they would publish more information as to what exact problem with the gas line, caused the explosion.
#35 | |
Sorry for the rant. As for the CSST line on your home, the concern about it is from lightening strikes, which, if the CSST becomes energized from, can lead to pin holes and then a fire if their is a source of ignition. Gas lines themselves don't just explode, you need: a leak, a sufficient build up of gas, and an ignition source. Proper bonding (basically grounding) of the CSST should bring that electricity to ground without causing pinholes. |
#36 | ||
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it. |
| Display Modes | |
| Flexible copper gas line | wease | Plumbing | 6 | 04-09-2008 11:40 AM |
| Flexible pipe for plumbing | bigboyjoel | Plumbing | 2 | 06-26-2007 12:43 PM |
| Replacement pipe for hot water heat? | Tmb9862 | HVAC | 18 | 01-12-2007 04:31 PM |
| tips for old gas line removal? | Dusty | Plumbing | 13 | 10-24-2006 10:40 AM |
| Need to support 15th of ABS pipe | irishtimes101 | Plumbing | 3 | 09-01-2006 12:09 PM |
