Old 10-21-2009, 12:46 PM   #16
Gas Line Extension - Can I use Flexible Pipe?
I'm looking forward to this thread popping up again sometime in the fall of 2012.
More On This Topic
The last part of creating your home renovation plan is to create a master plan of all the tasks that need to be done. Create a plan that has the order in which the construction will be done, and within each category, for example electric, plumbing, walls... Read More »
So you've decided to take the plunge. You want to try improv comedy and you want to start with an improv comedy class. I want to talk to you about how do you choose the place that you're going to take improv comedy classes. The number one tip I would... Read More »
Sometimes adult children are faced with the difficult realization that a parent is not able to keep up with his personal and financial affairs any longer. Becoming a guardian or conservator of your parent, however strange it seems, could be necessary in... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
This area used to be a back porch where the ceiling drops down. This entire area was a back porch. This end segment of it was a laundry room. When we decided to make this an entry alcove, what we did was we had to end the plumbing here, we had to... Read More »
Flexible copper gas line wease Plumbing 6 04-09-2008 11:40 AM
Flexible pipe for plumbing bigboyjoel Plumbing 2 06-26-2007 12:43 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
tips for old gas line removal? Dusty Plumbing 13 10-24-2006 10:40 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
