Gas Line For Dryer - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2008, 05:39 AM   #16
Union HVAC Tech.
It is a pretty standard fitting. You shouldn't have a problem.
bigMikeB is offline   Reply With Quote
Old 01-27-2008, 08:50 AM   #17
DIY Expert in Training!
I have a plumber coming out Wednesday to do this for me. He said he will tap into the main line. Another plumber planned on adding a T to the line for the water heater. He said that could restrict the gas flow to the water heater and dryer. One could burn out fast because of trying to get more gas.
gone_fishing is offline   Reply With Quote
Old 01-27-2008, 10:23 PM   #18
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Gas Line To Dryer
"NO" the big DANGER is carbon monoxide poisoning from the burner's one or more starving for gas ! !
the system was sized when the house was build or gas piping was first installed for "ALL"
gas fixtures running at max demand like in the middle of winter the boiler is on, the water heater is on, you have all the extended family over cooking all top burners and oven running
now somebody decides to dry clothes
and the next morning you are the lead story in the news ! ! family sicken or killed by "CARBON MONOXIDE"
MACPLUMB MASTER PLUMBER
P. S. THIS OFTEN HAPPENS IN WINTER TIME
MACPLUMB is offline   Reply With Quote
Old 01-28-2008, 05:11 AM   #19
Union HVAC Tech.
MACPLUMB the huge print is annoying, back off a tad. Look around the boards and try to fit in a little.
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
