Old 10-18-2011, 02:28 PM   #1
Gas line for direct vent fireplace
I'm putting in a direct vent fireplace in an existing fireplace alcove. The existing gas line ends with a gas ball valve and 1/2" NPT female. The gas line is black pipe to the meter. The fireplace, Medota Greenbriar, has a 1/2" female NPT fitting. The space where the gas line connections will be enclosed behind wall board, so I can't use a union.
Question: Are the flexible lines used to connect appliances suitable for use behind enclosed walls? Are there flexible lines available use use behind enclosed walls?
klingenfelter is offline   Reply With Quote
Replacing a wood with a direct vent fireplace Travlnman Remodeling 0 07-14-2011 11:44 AM
Venting for NG direct vent fireplace in basement fubar79 HVAC 4 03-23-2011 01:18 PM
Gas B vent fireplace venting option ? help cvcman HVAC 0 03-09-2011 10:14 PM
Water Coming Out of Vent Line?? dost559 Plumbing 3 06-11-2008 09:50 AM
Direct Vent Fireplace SnoBird Building & Construction 1 03-19-2007 10:06 AM
