gas line connecting to water heater
Depends on code. Some areas require that it is flex from the black iron to the appliance, with the drip leg back at the pipe a ways if required. That is just my .02.
You are second guessing that it isn't there, due to not seeing it in the pic, but for all we know, it is back at the end of that pipe, so I am not putting any more thought than should and leaving it as is.
Really, it is not our opinion to question why in posts like this, just state an opinion and let the OP decide if they are coming back for further questions, or making it a one post wonder.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
