Gas Hot Water Tank Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2013, 01:12 PM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 806
How far is the water heater from the farthest facet? If a long distance it might have been for a circulation pump
ddawg16 is online now   Reply With Quote
Old 06-14-2013, 01:33 PM   #17
The farthest hot water faucet is around 30 linear feet of water line. Our supply pressure is good everywhere. I was thinking maybe they tapped in a Humidifier?, but wouldn't that be on a cold line? Anyways, I see no harm in eliminating it? Thanks
John28 is offline   Reply With Quote
Old 06-14-2013, 01:50 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 806
Is that 1/2" or 3/4" lines? Almost looks like 1/2" in the photo....too small...
Old 06-15-2013, 12:22 AM   #19
I believe they are 5/8 lines, it's an older house. Not going to replumb the whole house though.
Old 06-15-2013, 09:19 AM   #20
MarginallyQualified
Rewards Points: 2,464
Pipe is measured from the INSIDE.
~5/8" outside (copper) will be 1/2" inside.
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Low water pressure + storage tank pyotrbee Plumbing 1 08-28-2012 08:02 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 09:20 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
