Gas Hot Water Tank Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2013, 11:30 AM   #1
I'm looking to replace my hot water tank, never did one, but looking for some advice.
What route should I go for a new Cold water shutoff? The one is in bad shape which I'll cut out. My thinking was the Sharkbite ball valve with braided flex line right to the cold supply of the tank. Do you trust these Sharbites, or should I use a ball valve with female ends, to thread sweated lines in?
Just looking at future change outs where both supplies with the Sharbites flex lines would thread to the tank. And my gas supply has a flex line, which all also replace. How much easier with 3 flex connections for future change outs could it get, or don't go this route?
I also have to check on an expansion tank, never had one, and i don't believe there is any type of pressure regulator on the water coming in. If this is the case, do I really need an expansion tank, as no other homes in this area have them? Thanks
John28 is offline   Reply With Quote
Old 06-12-2013, 12:16 PM   #2
These are the Sharkbites I was referring to
Old 06-12-2013, 12:29 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Instead of a sharkbite....I would sweat a 3/4" male threaded coupling...then you can screw on a 3/4" ball valve. After that you can use flex.
This is how mine looks.
The Following User Says Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (06-13-2013)
Old 06-12-2013, 12:56 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by John28 View Post
My thinking was the Sharkbite...
despite the enthusiasm so many have for these...
I continue to assert they are a repair item for use by maintenance hacks and when you don't have time to plan or get the correct materials.
If you don't know how to sweat copper... learn.
Allow for the time but this is a perfect opportunity
do I really need an expansion tank...
1) Call your county 2) look for a pressure reducer valve
The Following 2 Users Say Thank You to TarheelTerp For This Useful Post:
Javiles (06-12-2013), TheEplumber (06-12-2013)
Old 06-12-2013, 09:45 PM   #5
thanks for nice scan short picture ddawg16 also give some advice,me also clear about this matter
plumber12 is offline   Reply With Quote
Old 06-13-2013, 10:22 AM   #6
Bill Kearney
Rewards Points: 1,174
[QUOTE=TarheelTerp;1199955]If you don't know how to sweat copper... learn.
Allow for the time but this is a perfect opportunity/QUOTE]
Seriously. If the typical half-assed contractor can do it, so can anyone else.
The real key is make sure the pipe is dry before trying to heat it up for the solder. If there's any water still in the line then it'll never heat up evenly enough to get the solder going properly.
But it really is a pretty easy thing to do.
wkearney99 is offline   Reply With Quote
Old 06-13-2013, 10:37 AM   #7
I know how to sweat lines, just didn't want to hard line it right to the supplies, for easier future change outs. If tanks were as the same quality of older ones I'd have no problem hard lining it. But everything I read 5-10 years on tanks now? Believe it or not this tank is 28 years old and still works, but starting to gargle, as I didn't keep up with flushing the last several years, and the shutoff is in bad shape. So if I'm going to be replacing it more often, I want a easier quicker setup to deal with.
Decided to sweat male adapters as suggested with a ball valve, then flex line from there, I'm thinking Stainless Steel Rino Flex? Thanks
Old 06-13-2013, 10:40 AM   #8
JOATMON
ddawg16's Avatar
I wouldn't use SS.....it is more prone to cracking than copper. It can handle higher temps and pressure...but your copper will get no where near it's limit.
Old 06-13-2013, 10:47 AM   #9
Not that familiar with either, just did a lot of reading where most prefer the Stainlesss over Copper for this application? Thanks, I'll look into it more, before deciding? I'm in no real hurry, as it still works, but is definitely going to need changed.
Is there a particular Brand Copper Flex you prefer?
Old 06-13-2013, 10:56 AM   #10
JOATMON
ddawg16's Avatar
I may have to re-think my opinion on SS flex....at least in this application. I just did some searching and there seem to be a lot of good things said about it.
We use SS flex lines here...but in a much higher performance application...and the failures are always the same...cracking in the crease....
Old 06-13-2013, 11:24 AM   #11
Like I said, just what I been reading, but I have no expierence with either.
With SS, it is more expensive, and different qualities, as I read stay away from the cheaper.
Here's a link, that compares theirs to copper in the description, and has a lifetime warranty, but not sure if that would cover cracking?
http://www.hotwaterheaterdirect.com/...connectors.asp
They also say reusable and rebendable? Don't think I'd reuse them though, once bent to shape, and have been used for awhile?
Old 06-13-2013, 12:16 PM   #12
Bill Kearney
There's also the dissimilar metals issue. Don't know if/how that would apply here, but I've suffered more than one failure of a fitting when someone in the past used the wrong materials when mating up to copper.
Old 06-13-2013, 12:19 PM   #13
No galvanic effect stainless steel
Old 06-13-2013, 05:31 PM   #14
Rewards Points: 1,868
New hot water tanks come equipped with Dialectic nipples. Thats the stainless steel nipple with plastic liner out of your hot and cold inlet.
Old 06-14-2013, 12:06 PM   #15
Does anyone know what this T-fitting on the Hot line coming from the tank would have been for, or it's purpose? It has a threaded plug and is corroded some, which i was going to eliminate.
You can also see the Cold water shut off in the back, which I'll replace with a ball valve, as it's in bad shape too, Thanks
And no, I did not wrap that foam foil tape on the lines, it's always been there.
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 04:51 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Low water pressure + storage tank pyotrbee Plumbing 1 08-28-2012 07:02 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 08:20 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
