Gas Hot Water Tank Flue - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 09:30 AM   #1
gas hot water tank flue
Need some HELP! i am replacing the flue for the gas hot water tank. (the flue is straight up and through the roof) the previous homeowner said that water was leaking in between the roof boot and where the flue came through, so he applied an adhesive/caulk between the roof boot and the flue coming through. The flue has some rust spots and needs to be replaced, but its now "glued" to the roof boot. How can i dissolve the adhesive, or other wise get the existing flue out to replace with a new one???
kenco77 is offline   Reply With Quote
Old 04-11-2012, 09:33 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm not sure what it costs to put a new roof jack up, but from what I understand it's pretty inexpensive, and quite easy.
Journeyman Plumber
Old 04-11-2012, 09:59 AM   #3
There has been a new metal roof installed after the owner placed the adhesive. how much trouble it it to replace the boot with the new metal roof?
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 06:25 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Water tank problems chapmanm02 Plumbing 5 04-29-2009 07:11 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
