Gas Hot Water Tank Is 6 Yrs Old. Very Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2012, 10:46 AM   #1
Gas hot water tank is 6 yrs old. Very low hot water pressure
Throughout the whole house there is little hot water pressure, the cold is strong. What to do or check before I go to the expense of replacing the tank. Thank you.
sucarty is offline   Reply With Quote
Old 04-14-2012, 10:53 AM   #2
Rewards Points: 1,548
Get a garden hose spigot cap (one typically comes with a lawn sprinkler that allows daisy chaining, such caps are also sold separately.
With a pot or bucket to catch the water, and with the main water still turned on, open the drain valve at the bottom of the water heater. If you get a strong flow here then the hot water tank is not at fault for the low pressure.
While you are at it, drain more water out until any sand or discoloration disappears; may take more than one bucketful.
Use the garden hose cap if the water heater drain valve doesn't close completely.
Arteriosclerosis in the water pipes is a common reason for low water pressure, particularly in homes more than 50 years old. It is possible for the hot water line to clog sooner than the cold water line.
A 6 year old water heater is rarely if ever responsible for low water pressure.
Old 04-14-2012, 10:53 AM   #3
Rewards Points: 14,306
What type of pipes do you have? Steel, CPVC, copper?
There has to be a 3/4 supply line in and out of that tank, if someone used 1/2" instead that could be the whole problum.
The 3/4" needs to run all the way to the end of the lines, and can then be steped down to 1/2 for the supplys to the fixtures.
If you have a globe or or gate valve as a shut off on the tank it could not be opened all the way or the shaft could be broke off inside the valve. Really needs to be a ball valve instead.
Old 04-14-2012, 11:28 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is supply valve open to water heater?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-14-2012, 02:05 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
You could have a defective heat trap valve in the hot water output line of your water heater. Heat trap valves can be internal or external to the water heater. Here's a picture of external heat trap valves:
Sediment from the tank can clog the hot water heat trap valve causing low hot water flow.
External heat trap valves can be replaced. As far as I know, heat trap valves internal to the water heater cannot be replaced.
If you do have a defective or clogged external heat trap valve on the hot water output line, I suggest replacing it (and the one on the cold line) using heat trap pipes instead of valves. Heat trap pipes will never clog and will allow maximum hot water flow.
EDIT: If you do have heat trap valves on your water heater and the one on the hot water line is clogged by sediment, I have an idea on how you could unclog it without doing any plumbing work. Never tried it personally but I believe it might work.
BTW, have you drained/flushed your water heater in the 6 years you've had it? If so, how often?
HRG
Homerepairguy is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
