Gas Hot Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2011, 08:31 PM   #1
gas hot water tank
Im having a promlem getting an A O Smith gas hot water tank to relight . I have replaced thermol couple and after doing so it cycled thru once by heating up water. But then after water was hot the burner shut off and so did the pilot. I was only able to get the pilot to light only when holding the red pilot light button b ut as soon as i let go the pilot goes back out . I have cheked the fresh air intake in the bottom of tank and that is clean . Was wondering if the FVIR sensor was bad and if so how to test it ?
seedj is offline   Reply With Quote
Old 11-17-2011, 12:19 PM   #2
how
Rewards Points: 1,100
Does this tank have flame quard technology? Does it have a limit switch connected to the inner door that is wired to the gas valve? If so then it has a tiny reset bar in the middle of that limit switch that needs to be pressed back in to relit it.
how is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Can I use existing hot water tank for radiant floor? Red Squirrel HVAC 4 12-14-2010 07:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
