Gas hot water heater problem I think....
They are there to relieve the pressure in the water tank if it gets too high. A common problem is for someone to install a back flow preventer on the cold side....water heater heats up the water....it expands...pressure increases. The PRV prevents the tank from ruptureing.
If the tank is several years old, the valve could be going bad. I believe you can replace them....you just have to turn off the power and water.
Hopefully one of our experts will chime in with more exact details.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
