Gas Hot Water Heater Leaking Or Not? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2006, 12:04 AM   #1
gas hot water heater leaking or not?
I have a Whirlpool gas 67 gallon hot water heater. Yesterday I was cleaning and noticed there was puddles of water sitting on the top where the copper connections are. I whiped it all dry and after a bit the water returns. In between the panel and the top of the water heater there is insulation... you can see this in the holes where the water connections are... the insulation is soaked and water slowly puddles up around the copper connections..??? Is this normal? I haven't lived in this house long so I am not sure if it has given any problems before or what is the solution? All advice welcome!
Thank you!
handymama is offline   Reply With Quote
Old 12-30-2006, 09:39 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Not normal, how old is this heater?
Can you try to tighten up the connections?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-30-2006, 05:09 PM   #3
RE: gas hot water heater leaking or not?
There is a date on there of 7/2003 I don't know if that is the manufactured date or the installation date... last night I tried to dry up the water again and I found a slow leak on the right side connection on the top. I don't know much about plumbing, but I am going to try and tighten it up hopefully it doesn't crack..
Old 12-30-2006, 06:22 PM   #4
Journeyman Plumber
If it won't fix the leak, is this something you will be able to take apart and install a new connection?
Sounds like it's a water heater flex connect. These are easy to replace if needed.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 06:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
