Gas Hot Water Heater, Burner Will Not Ignite - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2009, 10:49 AM   #1
Gas Hot water heater, burner will not ignite
I woke up to cold water. I thought right away it was the thermocouple so I ran in town and bought a new one. I replaced the thermocouple and the pilot light is fine. My problem is I cannot get the burner to ignite. I have done everything correctly, ran the water while pilot is lit, turned the thermostat up and down and off and on. I can see the gas ignite when I turn the thermostat on and go out when i turn it off. I just cannot get the burner to take off. Any help??
hammerdome is offline   Reply With Quote
Old 10-14-2009, 11:03 AM   #2
the Musigician
DangerMouse's Avatar
did you reset the pilot light switch to the 'on' position after lighting it?
DM
Old 10-14-2009, 11:40 AM   #3
Yes, I did turn pilot light back to the "on" position. I tried several times. I just dont understand.
Old 10-14-2009, 11:49 AM   #4
Rewards Points: 1,514
Test that the thermocouple is working properly (from the looks of it yours is so you don't need to do this test).
1. With the pilot light blown out and the heater let to sit for 10 minutes, lighting a match and trying to relight the pilot fails if you don't push down the button.
2. Push down the button, light the pilot, and let go of the button 5 seconds after the pilot light catches. The pilot light should work but go out when you let go of the button.
3. Push down the button, light the pilot, hold the button down for 55 seconds and let go. The pilot light should stay lit.
If you see the flame get a little bigger when you turn up the thermostat but after 15 seconds the burner does not come on full, you probably have a problem in the control box where the thermostat knob is or in the fat tube leading down to the burner.
The flame should not get bigger when you adjust the thermostat if you have not turned the small knob or button stem from "pilot" to "run".
Old 10-14-2009, 11:49 AM   #5
the Musigician
let me understand, you see a pilot light, when you turn up the thermostat, you see the gas ignite....
wouldn't that BE the burner firing up? if so, just wait for the water to heat up?
DM
Old 10-14-2009, 04:24 PM   #6
Do you think the solenoid might be bad?
Old 10-14-2009, 04:27 PM   #7
DM
The gas that I see ignite is the little bit of gas the comes out of the thermostat side. The big tube leading to the burner I think is my problem. No gas is coming out of the big tube.
Old 10-14-2009, 04:31 PM   #8
the Musigician
maybe a spider made a nest in the tube? it's happened before.
could be solenoid....
DM
Old 10-14-2009, 05:04 PM   #9
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
No hot water !
THE GAS CONTROL THERMOSTAT VALVE HAS A ONE TIME FUSIBLE LINK
THAT HAS BURNT OUT THEREFORE THE GAS VALVE IS BAD AND NEEDS TO BE
REPLACED WHAT BRAND ?
MODEL NUMBER ?
SERIAL NUMBER ?
I CAN TELL YOU WHERE OR HOW TO GET A REPLACEMENT GAS VALVE !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-28-2008 11:18 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
