Gas Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 03:37 PM   #1
gas hot water heater
just changed thermocople and piolt light stays lit but burner doesnt
ronald duane is offline   Reply With Quote
Old 04-16-2011, 09:51 PM   #2
Rewards Points: 1,418
Turn the little knob from the "pilot" position to the "on" or "run" position.
Slowly turn the large (temperature) knob all the way down to the lowest or "vacation" position. Then slowly turn it up. You will probably hear a click and then the burner should come on. If not there is probably a problem with the entire control assembly.
If you get it to work but the temperature knob has to be in the "very hot" range to get decent performance, then the control parts are showing their age.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
