Gas Furnance Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2010, 08:33 PM   #1
nlm
Gas furnance overflow
Why does the water come out of overflow on gas furnance?
nlm is offline   Reply With Quote
Old 11-09-2010, 10:46 PM   #2
Picky Plumber
Not so sure what you mean by "overflow". If you have a 90%+ high efficiency unit, then the water would be created by condensation of the flue gases. You can tell if it's a high efficiency unit if the vent piping for the unit is non-metallic (plastic, normally PVC).
Plumber26 is offline   Reply With Quote
Old 11-10-2010, 11:01 AM   #3
By overflow, are you referring to the pressure relief valve? If so, then the pressure within your heating unit is too high, and something needs to be corrected to lower that pressure.
H8Mondays is offline   Reply With Quote
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
overflow drain in non overflow sink? forresth Plumbing 1 10-06-2010 07:09 AM
Quatro Mba 080 NH2R furnance manual wolfden13 HVAC 1 02-10-2010 05:26 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 06:39 PM
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
