Gas Enough To Go Around - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2013, 04:27 PM   #16
Rewards Points: 20
I was just kidding about sawing pipe, thanks for telling me to hire a professional, but i think this is diy forum you don't seem to know what diy stands for, i am quite capable of screwing pipe together, don't make it seem like a hard thing just because you do it professionlly, this is all my fault everytine i try to reach out for help , i run into people like you with bid heads
mowpar is offline   Reply With Quote
Old 09-21-2013, 04:33 PM   #17
Plumber
I was just looking out for your health a safety.
Like I said, if your going to screw some gas pipe together, just make sure you do it right.
Without the proper permits, if something awful happens ( like blowing up your house ) , you are likely to find that your home owners insurance Is NOT going to cover Illegal work.
Just Saying, do what ever you fell comfortable with.
DidIDoThat is offline   Reply With Quote
Old 09-21-2013, 04:40 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 354
We see all kinds of people here mowpar- some competent, some not.
Topics such as gas piping are approached cautiously for that reason.
I suggest you search online for a gas sizing table to get your proper sizing.
Of course, you'll need to know the total load, branch line loads and the length for these lines.
It would also be wise to get the proper permit and inspections as your homeowners insurance or futur buyers may be effected.
Also, some area just flat out don't allow home owners to do gas piping
Old 09-21-2013, 06:07 PM   #19
Rewards Points: 20
In statement above "just make sure you do it right"
This is the reason I asked questions on this forum. I will go to another help forum, maybe there I will get the help I need.
Good by , and thanks
Old 09-21-2013, 07:44 PM   #20
Rewards Points: 1,706
I know how steel pipe is measured, did you want me to saw the line in half to make sure,
It's really very Obvious what size gas lines are.
Old 09-22-2013, 11:43 AM   #21
Rewards Points: 2,512
National Fuel & Gas Code 5.4.2.2 says "The total connected hourly load shall be used as the basis for piping sizing assuming all appliances are operating at full capacity simultaneously."
Remember that each fitting whether it be a tee, 90 elbow, 45 elbow has an equivalent length of pipe measurement. Reference the NFGC for table B.3.2 which gives equivalent lengths of pipe for a fitting.
Also Table 6.2(a) gives the capacity in cubic feet for certain diamter pipes at certain lengths. One cubic foot of natural gass is equal to about 1027 BTUs
gas enough to go around-close-up-cap-cubic-feet-gas-per-hour.jpg   gas enough to go around-table-20b_3_2.jpg
hammerlane is offline   Reply With Quote
Old 09-22-2013, 12:20 PM   #22
Rewards Points: 242
line feed is 1 inch 3/8 outside dia.
Good luck brother. Make sure those connections are leak free.
collegetry is offline   Reply With Quote
Old 09-22-2013, 12:30 PM   #23
Pipe service to house is 1 inch, and you suggest to run this same size to a 30 inch range????
I have seen a lot of things in construction but never a one inch gas pipe for a range, how old did you say you were?
The larger pipe run fairly close to stove then reduce down from there. I dont see where anyone suggested to run 1" into the stove. This is for a residence as you stated in post #1.
Old 09-22-2013, 12:34 PM   #24
I added a gas line for my outdoor grill. Ran 1" to a point about 4 feet from the outside wall then used a 1 x 1 x 1/2 tee to reduce down before exiting the rim joist.
gas enough to go around-11111111.jpg   gas enough to go around-8close-up-grill-shut-off.jpg   gas enough to go around-10-far-out-shutoff.jpg
Old 09-22-2013, 01:24 PM   #25
Rewards Points: 242
this is my argument for not having to check this ,,, am i wrong???? I live in the city with city gas line , i am quite sure that i would not have the only house that would have this many gas hook ups, others have this many and maybe more.
Your argument is other homes in the neighborhood have that many gas hook ups so you dont need to check it. So what if that means other houses in the neighborhood are undersized for their gas consuming appliances? What would you conclude from that?
