Gas Enough To Go Around - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2013, 10:55 PM   #1
Rewards Points: 20
gas enough to go around
When i moved into my house it had a gas hot water, baseboard heating, boiler system.
No other gas appliances. I have since put in a little gas heater for bathroom, and a gas hot water heater.
I am now wanting to put a 30 inch gas range on the same gas line feed, would there be a problem in doing this? I have read such things, as checking to see if the pressure is there to allow this, but, this is my argument for not having to check this ,,, am i wrong????
I live in the city with city gas line , i am quite sure that i would not have the only house that would have this many gas hook ups, others have this many and
maybe more. A
All help greatly appreciated
mowpar is offline   Reply With Quote
Old 09-20-2013, 11:10 PM   #2
Rewards Points: 1,878
That would entirely depend on your gas line size and distance. Does your house have a 1 inch main gas line?
Old 09-20-2013, 11:15 PM   #3
There are many things to consider when adding gas appliances, but the first consideration is the size of the pipe serving your house. For example, a 1/2" line will only fire a combined 45000 btu over a measured distance of 100'.
So a few questions that that need to be answered are in order to give you the correct response are;
- What is the size of the line that serves your house?,
- What the maximum output ratings of all the appliances you currently have connected? You'll find that info on each units ratings plate.
- What are the ratings of the units that you would like to install?
There's lots more info needed, but lets start with the basics and go from there.
VIPlumber is offline   Reply With Quote
Old 09-21-2013, 08:23 AM   #4
Rewards Points: 20
40,000 for hotwater ,,, boiler is 120,000 and 96,000 out, line feed is 1 inch 3/8 outside dia.
Old 09-21-2013, 08:26 AM   #5
Rewards Points: 20
Seems that i have to post in short choppy answers,, for some reason browser, shuts down when i am in the middle of responding
Old 09-21-2013, 08:28 AM   #6
Rewards Points: 20
I have not looked into ranges, yet is there no industry standard that could be substituted fot now? Line needed to hook stove up will be approx, 34 feet
Old 09-21-2013, 09:03 AM   #7
An old Tradesmen
Rewards Points: 6,960
Gas line needs to be sized for the total draw and length of the line.
If your gas line is 1" black pipe, measuring 1-1/4" OD. At 40 total length of 60 foot(includes equivalent length of fittings), it will handle your current load(160,000 BTUs) plus another 35,000 BTUs. Meaning you would notice a slight drop in your range performance when all appliances are running using the rated input.
If total length is longer then 60. Either the whole line will need to be resize, or a separate line an for the range.
Old 09-21-2013, 10:21 AM   #8
Rewards Points: 20
What size pipe should i use from the line into house area to the range 34 feet away then?
Old 09-21-2013, 02:40 PM   #9
An old Tradesmen
Probably going up to a 1-1/4" line would handle your full load.
Steel pipe is measured by its inside diameter.
Old 09-21-2013, 03:09 PM   #10
Rewards Points: 20
Pipe service to house is 1 inch, and you suggest to run this same size to a 30 inch range????
I have seen a lot of things in construction but never a one inch gas pipe for a range, how old did you say you were?
Old 09-21-2013, 03:11 PM   #11
Rewards Points: 20
I know how steel pipe is measured, did you want me to saw the line in half to make sure,
Old 09-21-2013, 03:17 PM   #12
Plumber
Brother, after reading all your post, it is clear you have NO idea what your doing.
Gas is nothing to play with, you might want to think about hiring a pro for this job.
If you do it yourself as a minimum pull the REQUIRED permits and have a city inspector check your work.
DidIDoThat is offline   Reply With Quote
Old 09-21-2013, 03:17 PM   #13
Rewards Points: 20
Old 09-21-2013, 03:18 PM   #14
Plumber
If you do get the wife and kids out of the house , and PLEASE take pictures.
Old 09-21-2013, 03:19 PM   #15
An old Tradesmen
You posted the outside diameter in post number 4.
I would run a 1-1/4" line from the meter to the split for the first appliance, and then decrease size or the remaining load, and run that size until the second appliance, and then decrease size to what the final appliance needs.
