Gas Cooktop Using 20lb Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2009, 11:09 AM   #1
Jsc
Gas cooktop using 20lb tank
I have a new LP two burner cooktop in my kitchen. The small burner works fine, but the large one "pops" when first turned on (after igniting with electronic ignition) and sometimes blows the flame out completely. Seems to be a pressure thing, but I can't figure it out. For now I am running it on a 20lb tank. The temperature outside (where the tank is) is -14c. Any ideas?
Jsc is offline   Reply With Quote
Old 02-10-2009, 02:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,... Sounds like the regulator might be freezing up...
Bondo is online now   Reply With Quote
Old 02-11-2009, 11:48 AM   #3
I found out, by accident, that the portable propane tanks can contain a different type of propane than what you have delivered to your home. A factory I worked at tried to use the fork lift propane tanks for a space heater. Had all kinds of problems with it. When we contacted the propane company, we were advised that the contents of the tanks were not the same for heating as they were for running equipment. The 20 pound tank may not have enough pressure for running your cooktop also. Actually sounds more like too much pressure since it pops and blows out the flame.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
