Old 02-06-2007, 06:17 PM   #1
Smile
Garden Hose
Hello, I was wondering, on a normal house, what is the PSI of a garden hose
calabashfire is offline   Reply With Quote
Old 02-06-2007, 06:19 PM   #2
Garden Hose
Normal hose has 40 psi.
cibula11 is offline   Reply With Quote
Old 02-06-2007, 06:25 PM   #3
Garden Hose
thanks
Old 02-07-2007, 07:29 AM   #4
Garden Hose
Normal....depends on the water pressure of the incoming service. If the house pressure is 40#, the hose will have about the same. If the house pressure is 80# the hose will be the same. Typically, "good" water pressure in a house is between 40 and 80#. Anything over 80# is high pressure and the installation of a pressure reducing valve is recommended.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
Ductless unit has dripping hose in basement tockfull HVAC 3 07-20-2007 09:17 AM
replacing hose bibb leroyme Plumbing 23 04-16-2007 06:45 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
