Garbage Disposal Shakes Counters - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 06:20 PM   #1
Question
Garbage disposal shakes counters
Hello,
I just installed a new garbage disposal myself and I'm afraid I might have done something wrong. There is no leaking whatsoever, but the entire countertop often shakes for a few seconds when I turn the disposer on. I'm wondering if I may have put on a unit that is too powerful? The unit is a 1hp Waste King that I purchased based on good reviews in consumer reports without stopping to think if 1hp was too much. The counter is laminate. I'll post some pictures if anyone thinks it would be helpful to diagnose the problem.
Thanks in advance,
Brian
muse_ee is offline   Reply With Quote
Old 08-25-2009, 06:23 PM   #2
Registered User
Termite's Avatar
I'd suggest removing the unit from the underside of the sink and the plumbing, then turn it on and feel for vibration. If it shakes or vibrates hard when it isn't mounted then I'd take it back. It should run reasonably smoothly and it certainly shouldn't shake the sink, plumbing or countertops.
Old 08-26-2009, 07:50 AM   #3
You may find that the problem is the sink thickness. If you have a 22 gauge stainless sink and a 1 HP disposal, it may be causing flex. I also agree that it may be the disposal itself.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-18-2016, 09:17 AM   #4
Rewards Points: 2
Re: Garbage disposal shakes counters
I have the same problem with my waste king. I bought the 2600 model, 1/2hp. If the disposal is empty it runs smooth and quiet but if there is any garbage along with it being full of water, its shakes the entire counter top until its nearing being empty. then it runs smooth and quiet again. I'm wondering if the discharge pipe is too small and the unit it trying to push too much, to fast through it causing the disturbance. If so, any suggested fixes?
Jim88 is offline   Reply With Quote
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 10:13 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
Garbage Disposal howard.wheaton Electrical 7 05-10-2009 06:36 AM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 03:00 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 06:35 PM
