Garbage Disposal Leaks Out Bottom But Only When Running - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2010, 10:36 AM   #1
Rewards Points: 28
Garbage disposal leaks out bottom but only when running
I did a search and found lots of info but the threads didn't specify if it leaked all of the time or just when the disposal was running. Mine dosen't leak at all unless I turn it on and then it starts to drip out of the bottom where there is some screw holes. I'm guessing it probably needs to be replaced still but thought I'd double check if this is different and something I could possiable fix. Thanks
sprtfan is offline   Reply With Quote
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Is it possible to take apart a garbage disposal? sillyboy22 Plumbing 5 04-03-2010 11:21 AM
garbage disposal, which bowl? ninghai Plumbing 9 01-26-2010 01:43 PM
Running wires across bottom of joists WaldenL Electrical 8 01-25-2009 04:00 PM
leaks when shower is running but from where? bellsnj Plumbing 7 11-28-2007 11:28 AM
