Garbage Disposal Leaking From Bottom - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2010, 07:13 PM   #1
Rewards Points: 184
Garbage disposal leaking from bottom
My garbage disposal leaking from bottom, is there a fix for it? Or does it need to be replaced?
Does that happen often?
abefroman is offline   Reply With Quote
Old 09-11-2010, 07:15 PM   #2
Time for a new one. I see it every couple of months, and there is nothing you can do. Hundred bucks for a badger 5 is easy money if you use it often (or the wife does )
the_man is offline   Reply With Quote
Old 09-11-2010, 07:34 PM   #3
Rewards Points: 184
Badger.....badger!!! I don't need no stinking badger!
Old 09-11-2010, 07:41 PM   #4
Well fine then, apparently the wife likes fancy disposals put in whatever you want, they'll all make sausage just fine
Old 09-11-2010, 08:00 PM   #5
Rewards Points: 184
I had a badger 1 in the already, 1/3hp, should I go with the badger 5?
Old 09-11-2010, 08:18 PM   #6
lloydb's Avatar
I like the badger 5 for residential applications. They are nice disposals. Don't forget to knock the plug out for your dishwasher hookup if that's where your dishwasher drains.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 09-11-2010, 08:24 PM   #7
Rewards Points: 150
Sears disposers use the same motor as ISE
rudolph58 is offline   Reply With Quote
Old 09-11-2010, 08:26 PM   #8
badger 5 is a good basic disposal and the smallest one you should get. If you wanna spend a little bit more, the ISE Evolution compact is around 170 at depot, 3/4 HP, runs quieter, and is a much better quality
Old 09-11-2010, 09:07 PM   #9
lloydb's Avatar
I installed a 3 phase ss-75 insinkerator awhile back (commercial kitchen). What a beast that thing was.
Old 09-11-2010, 09:36 PM   #10
Rewards Points: 184
My dish washer appears to drain to a pipe and not through the disposal.
Old 09-11-2010, 10:03 PM   #11
Rewards Points: 184
The store didn't have the badger so I got a similar one.
How do I connect the black piece to the white piece? There are no threads on the black piece.
TIA
Old 09-11-2010, 11:52 PM   #12
lloydb's Avatar
With a slip nut and beveled washer like the one on the left pipe.
Old 09-11-2010, 11:58 PM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
MY complaint with the Badger series is they are very noisy. The uooer end ISE's are much quieter. And $200 vs $100.
Coastal South Carolina
Old 09-12-2010, 12:09 AM   #14
Rewards Points: 184
Thanks!
I have a slip nut from the old one, but it falls off, its barely too big, Iw ill head to the store tomorrow and get a smaller one.
Old 09-12-2010, 12:22 AM   #15
Rewards Points: 184
Thanks!
Actually the one I had worked, looks like they are suppose to tighten themselves as the nut is screwed in.
Garbage disposal shakes counters muse_ee Plumbing 3 06-18-2016 10:17 AM
Installing reverese osmosis filter system - with a garbage disposal? J187 Plumbing 8 01-07-2010 09:46 PM
garbage disposal clogged amakarevic Plumbing 1 03-31-2009 02:16 PM
Garbage Disposal Dilemma (with pic) tommy potatoes Plumbing 13 03-23-2009 06:50 PM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 11:18 PM
