-   -   Garbage disposal leaking from bottom (http://www.diychatroom.com/f7/garbage-disposal-leaking-bottom-81185/)
abefroman 09-11-2010 06:13 PM
My garbage disposal leaking from bottom, is there a fix for it? Or does it need to be replaced?
Does that happen often?
the_man 09-11-2010 06:15 PM
Time for a new one. I see it every couple of months, and there is nothing you can do. Hundred bucks for a badger 5 is easy money if you use it often (or the wife does :laughing:)
abefroman 09-11-2010 06:34 PM
Badger.....badger!!! I don't need no stinking badger!
the_man 09-11-2010 06:41 PM
Well fine then, apparently the wife likes fancy disposals :laughing: put in whatever you want, they'll all make sausage just fine :chef:
abefroman 09-11-2010 07:00 PM
I had a badger 1 in the already, 1/3hp, should I go with the badger 5?
lloydb 09-11-2010 07:18 PM
I like the badger 5 for residential applications. They are nice disposals. Don't forget to knock the plug out for your dishwasher hookup if that's where your dishwasher drains.
rudolph58 09-11-2010 07:24 PM
Sears disposers use the same motor as ISE
the_man 09-11-2010 07:26 PM
badger 5 is a good basic disposal and the smallest one you should get. If you wanna spend a little bit more, the ISE Evolution compact is around 170 at depot, 3/4 HP, runs quieter, and is a much better quality :thumbsup:
lloydb 09-11-2010 08:07 PM
I installed a 3 phase ss-75 insinkerator awhile back (commercial kitchen). What a beast that thing was.
abefroman 09-11-2010 08:36 PM
My dish washer appears to drain to a pipe and not through the disposal.
abefroman 09-11-2010 09:03 PM
The store didn't have the badger so I got a similar one.
How do I connect the black piece to the white piece? There are no threads on the black piece.
TIA
http://sphotos.ak.fbcdn.net/hphotos-...6_491331_n.jpg
lloydb 09-11-2010 10:52 PM
With a slip nut and beveled washer like the one on the left pipe.
http://www.plumbingsupply.com/images...-segmented.jpg
rjniles 09-11-2010 10:58 PM
MY complaint with the Badger series is they are very noisy. The uooer end ISE's are much quieter. And $200 vs $100.
abefroman 09-11-2010 11:09 PM
Thanks!
I have a slip nut from the old one, but it falls off, its barely too big, Iw ill head to the store tomorrow and get a smaller one.
abefroman 09-11-2010 11:22 PM
Originally Posted by abefroman (Post 499704)
Thanks!
Actually the one I had worked, looks like they are suppose to tighten themselves as the nut is screwed in.
